Mars rover has uncertain future as sixth anniversary nears
The team may not be able to position the rover's solar panels to tilt toward the Sun to collect power for heat to survive the severe martian winter. Provided by the Jet Propulsion Laboratory, Pasadena, California
By | Published: January 4, 2010 | Last updated on May 18, 2023
Spirit rover
Spirit attempted to turn all six wheels on Sol 2126 (Saturday, December 26, 2009) to extricate itself from the sand trap known as “Troy,” but stopped earlier than expected because of excessive sinkage.
NASA/JPL-Caltech
January 4, 2010
NASA’s Mars rover Spirit marked 6 years of unprecedented science exploration and inspiration for the American public Sunday. However, the upcoming martian winter could end the roving career of the beloved, scrappy robot.
Spirit successfully landed on the Red Planet January 3, 2004, and its twin Opportunity arrived January 24, 2004. The rovers began missions intended to last for 3 months, but they have lasted 6 Earth years, or 3.2 Mars years. During this time, Spirit has found evidence of a steamy and violent environment on ancient Mars that was quite different from the wet and acidic past documented by Opportunity, which has been operating successfully as it explores halfway around the planet.
A sand trap and balky wheels are challenges to Spirit’s mobility that could prevent NASA’s rover team from using a key survival strategy for the rover. The team may not be able to position the robot’s solar panels to tilt toward the Sun to collect power for heat to survive the severe Martian winter.
Nine months ago, Spirit’s wheels broke through a crusty surface layer into loose sand hidden underneath. Efforts to escape this sand trap barely have budged the rover. The rover’s inability to use all six wheels for driving has worsened the predicament. Spirit’s right-front wheel quit working in 2006, and its right-rear wheel stalled a month ago. Surprisingly, the right-front wheel resumed working, though intermittently. Drives with four or five operating wheels have produced little progress toward escaping the sand trap. The latest attempts resulted in the rover sinking deeper in the soil.
“The highest priority for this mission right now is to stay mobile, if that’s possible,” said Steve Squyres of Cornell University in Ithaca, New York.
If mobility is not possible, the next priority is to improve the rover’s tilt, while Spirit is able to generate enough electricity to turn its wheels. Spirit is in the southern hemisphere of Mars, where it is autumn, and the amount of daily sunshine available for the solar-powered rover is declining. This could result in ceasing extraction activities as early as January, depending on the amount of remaining power. Spirit’s tilt, nearly 5° toward the south, is unfavorable because the winter sun crosses low in the northern sky.
Unless the tilt can be improved or luck with winds affects the gradual buildup of dust on the solar panels, the amount of sunshine available will continue to decline until May 2010. During May, or perhaps earlier, Spirit may not have enough power to remain in operation.
“At the current rate of dust accumulation, solar arrays at zero tilt would provide barely enough energy to run the survival heaters through the Mars winter solstice,” said Jennifer Herman, a rover power engineer at NASA’s Jet Propulsion Laboratory (JPL) in Pasadena, California.
The team is evaluating strategies for improving the tilt even if Spirit cannot escape the sand trap, such as trying to dig in deeper with the wheels on the north side. In February, NASA will assess Mars missions, including Spirit, for their potential science versus costs to determine how to distribute limited resources. Meanwhile, the team is planning additional research about what a stationary Spirit could accomplish as power wanes.
“Spirit could continue significant research right where it is,” said Ray Arvidson of Washington University in St. Louis. “We can study the interior of Mars, monitor the weather, and continue examining the interesting deposits uncovered by Spirit’s wheels.”
A study of the planet’s interior would use radio transmissions to measure wobble of the planet’s axis of rotation, which is not feasible with a mobile rover. That experiment and others might provide more and different findings from a mission that has already far exceeded expectations.
“Long-term change in the spin direction could tell us about the diameter and density of the planet’s core,” said William Folkner of JPL. He has been developing plans for conducting this experiment with a future, stationary Mars lander. “Short-period changes could tell us whether the core is liquid or solid,” he said.
StarDome
Observe the news!
Use Astronomy.com’s interactive star chart, StarDome, to locate and observe Mars in your sky. Click on the StarDome graphic to the right. Be sure to find and set your location under “Location Settings.” After you’ve set your location, click on “Show Names” — located just to the lower right of the star chart — and select “Mark One Specific Object.” Scroll down to find “Mars” from the list of objects. Highlight it and click OK.
If Mars is visible from your location, it will appear on the map. Track the object’s motion across the sky by adjusting the figures under “Date and Time Settings.”
