NASA and ATK successfully test five-segment solid rocket motor
Despite the cancellation of the Constellation program, there is still a strong chance that the booster could play a part in future launch vehicles.Provided by NASA Headquarters, Washington, D.C.
By | Published: September 1, 2010 | Last updated on May 18, 2023
ATK booster
Ignition of Development Motor-2: DM-2 is the largest and most powerful solid rocket motor designed for flight. The August 31 static test was conducted by ATK Aerospace Systems in Promontory, Utah. DM-2 is managed by the Ares Projects Office at NASA’s Marshall Space Flight Center in Huntsville, Alabama.
NASA
September 1, 2010
With a loud roar and mighty column of flame, NASA and ATK Aerospace Systems successfully completed a 2-minute, full-scale test of the largest and most powerful solid rocket motor designed for flight. The motor is potentially transferable to future heavy-lift launch vehicle designs.
The stationary firing of the first-stage development solid rocket motor, dubbed DM-2, was the most heavily instrumented solid rocket motor test in NASA history. More than 760 instruments measured 53 test objectives.
Prior to the static test, the solid rocket motor was cooled to 40° Fahrenheit (4.4° Celsius) to verify the performance of new materials and assess motor performance at low temperatures during the full-duration test. Initial test data showed the motor performance met all expectations.
“For every few degrees the temperature rises, solid propellant burns slightly faster and only through robust ground testing can we understand how material and motor performance is impacted by different operating conditions,” said Alex Priskos, first stage manager for Ares Projects at NASA’s Marshall Space Flight Center in Huntsville, Alabama. “Ground-testing at temperature extremes pushes this system to its limits, which advances our understanding of five-segment solid rocket motor performance.”
The first-stage solid rocket motor is designed to generate up to 3.6 million pounds (1.6 million kilograms) of thrust at launch. Information collected from this test, together with data from the first development motor test last year, will be evaluated to better understand the performance and reliability of the design.
Although similar to the solid rocket boosters that help power the space shuttle to orbit, the five-segment development motor includes several upgrades and technology improvements implemented by NASA and ATK engineers. Motor upgrades from a shuttle booster include the addition of a fifth segment, a larger nozzle throat, and upgraded insulation and liner. The motor cases are flight-proven hardware used on shuttle launches for more than 3 decades. The cases used in this ground test have collectively launched 59 previous missions, the earliest being STS-3.
After more testing, the first-stage solid rocket motor will be certified to fly at temperature ranges between 40° and 90° F (4.4° and 32° C). The solid rocket motor was built as an element of NASA’s Constellation Program and is managed by the Ares Projects Office at Marshall. ATK Aerospace Systems, a division of Alliant Techsystems of Brigham City, Utah, is the prime contractor.
